:connectors have corrosion and a visual inspection is needed. Testing via the ECU won't tell you this and if the resistance readings aren't right -- you'll need to pull the connector anyway. In adddtion to the dental pick -- small needled nose pliers help too - makes it easy to grab the spring clip and pull it off.
Thanks Guys! I am going to give it a try... Your great!
